ANODE REMOVAL
johnmuir
30 May 2001
HAVE REMOVED ANODE FROM HULL BUT CAN'T NUTS INSIDE HULL, UNABLE TO BUDGE. CAN'T THEREFORE REMOVE ANODE FIXING BOLTS. ANY GOOD IDEAS ?
JOHN MUIR
ccscott49
7 Sep 2001
The nuts must be there inside the hull somewhere, if they are the normal stud type, they are not glassed in are they? very unusual if they are.
Juggler7823
UK, North Wales
If proper anode studs have been used, it is not necessary to renew the studs each time the anode is replaced. The studs are fitted from inside and have a square flange to form a seal.
Roy
johnmuir
30 May 2001
Thanks for your replies. Still not sure of method to remove. I think there is a tool called a nut cracker or similar name. Has anyone used one and to what success?
johnmuir
30 May 2001
There not glassed in but coated with bilge paint which Ihave removed. They just will not budge and are starting to round at edges.
ccscott49
7 Sep 2001
John, You can use a nut splitter if you have room, but an angle ginder would also do the job, if the nuts can be got at with that, but be very careful, try and shield everything from the sparks generated, have a fire extigiusher, with a spare body and wear eye protection. The nut splitter is painless and no sparks etc. Halfords or any good tool shop should have one, they are cheap nowadays and you will use it again, I garauntee! Plus yopu can lend it to your mates, for beer!
johnmuir
30 May 2001
Thanks , I 'll try the nut cracker 1st and lend it out for beers. They like the odd pint at my club!
