Con_Brio
In the past month I've three times encountered a problem new to me in all the years I've been anchoring. It arises from wind over/across tide. The boat is a Sadler 29, light and easily driven, with a shallow fin and full-length skeg for the rudder. No anchor windlass. The anchor on the bow is a 25lb CQR with 15m chain and the rest rope; backup is a 35lb CQR with an all-chain rode. The 25lb-er has settled into its familiar East coast mud with the boat facing the tide; the wind has then blown the boat over and across the anchor, so that the cable is stretched bar-taut aft along the side. Twice I have found this when I wanted to raise the anchor. I couldn't budge it by hand and think that a windlass would simply have scragged the topsides as the cable came home - even worse with an all-chain rode. Letting out more cable achieved nothing. I tried sailing it out - no go - I tried motoring it out, fearful that the cable was near the prop - no go. Eventually all that heaving induced the anchor to drag and then it was possible, with difficulty, to swing the boat far enough clear to get the anchor up. I have a simple tiller lock which holds the rudder dead centre. Should I instead have lashed the helm hard over to impart a sheer before leaving her to her own devices? Tiller upwind?
The third time it happened was in the dark in an open roadstead - the Small Downs - where we were waiting for a fair tide to go round the N Foreland, and it happened directly after we had bedded the anchor in, before I had even thought about applying a sheer. The boat was leaning hard on the warp; the tidal stream atlas appeared to indicate that the tide would begin to rise before the stream turned; so I was afraid we might drag before she swung. However, after many visits to the foredeck, I found at 2.30 am that she had swung sensibly to the first of the N-going stream and I could get some sleep before riding the stream northwards.
Using two anchors as a routine does not appeal.
I can't think why I haven't encountered the problem before (though I did have the boat in the Med for 9 years, which is part of the answer). Perhaps I have never wanted to get under way in those circumstances before or been concerned about an exposed anchorage just after having spotted the potential problem.
Is imparted sheer the answer? It doesn't help once the problem has arisen.
