Steve C Cronin
N/A
Ive just received this from CA sources regarding "Anchoring" off of coasts in Italy and something puzzles me.
Coastal Waters Restrictions - Anchoring, Speed Limits & Swimming Areas
Italian anchoring regulations have been updated, and are summarised below. In addition, they appear to be enforced more rigorously than in the past. Regional authorities are authorised to make adjustments to them to suit local conditions. A CA member has recently been fined 344 Euros for anchoring too close to a beach south of Agripoli. The best advice we can give is always to check for the local variations with relevant local officials.
Maximum speed limit of 10 knots within 1000m of a beach/swimming area, and, always within 500 m of the coast;
Landing on a beach/ swimming area is only permitted through a marked landing corridor and at a max speed of 3 knots. Swimming is forbidden within the landing corridor.
If there is not a landing corridor then you can only approach a beach/ swimming area using oars, (no engine) ... i.e. row yourself ashore!
Anchoring is not permitted within 100m of the shore, but, where there is no beach, i.e, with cliffs or rock, there might be a locally approved relaxation to 50 m. Anchoring is not permitted within 200-500m of a beach/swimming area between 08.30am and sunset. This distance is usually subject to local regulations and is usually set between 200m (common) and 300m.
So, does this ** mean then that the relatively new practice of taking two lines ashore when "at anchor" in the med is made illegal unless you extend these lines to 100m each in length? Or, does it now (correctly in my view) define the "two lines ashore" as "Med mooring" and NOT "anchoring", if you see what I mean and thereby exempt it from these new regulations and thereby allowing you to "moor" much closer.
