Anchoring mishap - beware nylon rode
I also use nylon (after the chain) in my anchor rodes, but it is 16mm octo-plait, and always sinks in still water. However, in a tidestream, a wind from astern can drive the boat ahead until the angle of the rode is shallow enough for it to catch behind the keel.
I use a galvanised shackle, almost 1kg, with a loop of line attached, as a weight. After anchoring, I pass the loop round the rode and then the shackle, then the same again, and pull the shackle to tighten the hitch on the rode; then pay out another 5 metres.
The hitch never slips, and the rode never fouls the keel.
This is real fred drift, but as a non motor boater I thought they looked great! The only trouble would be how much bouncing the passengers would put up with.
Gunfleet....yes thats the problem, the boat will take anything but the deciding factor is the passengers. Into a head sea about F5-6 can be the limit at 30kts, however once the sea abaft the beam she can run along at 30kts all day in as big a sea as you like. Very rae to make any one sick but down below she is fitted out like an airliner!
Paul.
All nylon and Polyester sink be they 3 strand or octiplat.
Floating anchor warps are nasty nasty nasty.
