I think most of the advice and reasoning in the link is spot on.
One big good anchor has a lot going for it.
I think the article is 100% correct in all assumptions. I have twice tried the two anchor V formation, once in the Ionian with 60 knots of wind, and both times watched as the bows blew off and the boat just sheered from one side to the other - only momentarily were both anchors taking any load - when the bow passed through the wind. The potential problems in setting and retrieval make the exercise best avoided and I would never repeat it. Much better, in my opinion and as the article author states, is to have a backup anchor already prepared to deploy if dragging should occur or to move position for any reason, one of which could be another boat dragging down on you (happened to me this year).
Oh, and also - very important - use a new generation anchor.
You are right, nothing should be rejected out of hand, what didn't work for me may do so for someone else in different conditions and with a different boat. The times I used two anchors was with a Trapper 500, which has a pronounced sheer to the bow, making it much higher than amidships and presenting a large pressure surface to weather-cock in a gale. More modern, flat sheer yachts may not react in this way. But I know I will never be owning such a craft.Your point is well-made, but to my mind the benefits of being able to deploy two anchors are so great that it would de wrong to avoid it as a matter of 'policy'.
Obviously I don't know the precise set-up on your boat, and no doubt you've given it plenty of thought, but I'd raise the truism that any system isn't worth having unless it's quick and easy to deploy. (As someone who has sailed mainly single-handed, this is especially relevant to me).
I've never dragged with two hooks, but was set up so the second bower could be quickly ditched on a fender if needs be. (All single-handers are especially wary of dragging in wild conditions, since it's tricky to be at both ends of a boat and a cockpit windless control isn't a complete solution.)
Couldn't agree more about choice of anchor. Out here you can barely walk into a bar without someone offering you one of those hinged things cheap.
I could watch exactly that effect with two anchors in the sand over rock incident. It was reportedly a 60 knot bora (tents in a campsite ashore blew away) and the sheering put all load on each anchor successively and so I zig-zagged my way towards the beach. It was only after many attempts to re-anchor that one of them hooked into a rock crevice and held. The next morning I dived to discover the true nature of the anchorage - shown as such in my pilot book.I would worry that if one is insufficient, two separate anchors will drag one at a time as the boat sheers, hence my preference.
