bluedragon
I don't like using tripping lines in a conventional way (with buoy) for a variety of reasons. But there are some anchorages where it's more than advisable to have something in place. So I've been thinking...
a) Instead of a buoy, a line running from the anchor and secured to the chain say 10-15m up. I'm unlikely to be in any more depth than this when the rode is vertical, so this should give enough to get it back on board. So long as this line is the same length as the anchor chain at the fitting point and firmly attached, I don't see it's going to cause any problems (like accidently tripping the anchor) is it? It's likely to be sitting on the bottom with the chain, though I suppose it could snag on something. Is this a better method than trying to pass a chain strop down the rode and over the anchor after it's fouled?
b) Tripping the anchor with either of the above lines: The idea of doing this by hand from a dinghy with a 14kg anchor well dug in and fouled is a non-starter in my book. So how about we take the tripping line back on board over the bow roller and use a winch...or motor ahead over the anchor?
Now all this is theory right now as I haven't tried any of the ideas...but I'm sure somebody has and will tell us the pros and cons as well alternatives
