noelex
Just a word of caution to anyone planning to adjust their Fortress to 45 degree setting based on this test. This setting is only suitable for soft mud.
If you try and use the 45 degree setting in a substrate that is slightly too firm the anchor will not work at all. The conventional 32 degree setting will allow the anchor to work in any sort of substrate. In a very soft substrate the holding power will be higher on the 45 degree setting, but you need to be sure of the substrate before making the adjustment.
The instructions for making the adjustment are here:
http://fortressanchors.com/anchors/fortress/fluke-position
It is also worth checking your Fortress is not accidentally set to 45 degrees. I see a few that are.
