BelleSerene
All that yanking before fitting the snubber may feel satisfactory, but as has been pointed out all it's doing is smoothing the force applied to the anchor while you're applying the force with engine and waves. So the peak force you apply is lower than it is if, unsnubbed, wave motion varies it every couple of seconds. So long as you bother to apply a reasonable setting force with engine or wind in the first place, the anchor will set fully so it makes no difference whether you've fitted the snubber first. But there's a force at which any anchor will break out - and by not smoothing the force it's more likely that a peak yank will loosen the anchor's hold and you'll never know it. So snubbing the anchor without snubber fitted really achieves very little to nothing, and runs a small risk of defeating its purpose.
Anyway, isn't the bigger picture this? Feels to me that the focus on digging the anchor in with such hard, unsnubbed tugs really deeply provides more peace of mind than real security. It distracts from the fact that once the tide changes, which will be within six hours of you anchoring, the pick is going to have to dig in the other way around (unless there's such little tidal force that it stays put, operating backwards, in which case giving it such an extreme yank was unnecessary anyway) - and this time it's going to have to do all the setting by itself, unaided by all that un-snubbed tugging with an engine. (I believe, BTW, this is the best reason for using a NG - and I do mean concave - anchor. You are going to check your anchor's initial set anyway, so what most defines your safety at anchor is the thing's oft-ignored ability to re-set on change of tide, without first dragging.)
