Ubergeekian
Current RYA Day Skipper booklet, page26, chain 4 x depth & warp 6 x depth.
Perhaps new generation anchors need more cable out?
As a mathematician, you can calculate the angle. We know that a typical 15 to 20kg anchor can hold up to 5,000lb force, that it will be connected by an 8mm chain whose weight and displacement are known, giving us a down force over the length of the chain. Let's say 42m of chain out in 6m of water . . . what is the reduction in angular pull from a straight line?I also believe the frequent assertion that the catenary flattens and the rode becomes straight in any sort of blow to be false in general(1): how do you know? How have you determined it? Just by looking at the few meters near the stem-head, from above?
Errm. Was the chain under water? And, of course, much of the point here is that the angle at the anchor differs between anchors - and perhaps bottom structure - to the degree (groan!) that we're working with over 10% uncertainty.But 8 degrees remains a mantra without anybody providing either empirical evidence or theoretical justification. I at least tried the experiment with a tractor and 60m of heavy chain.
