Bristolfashion
I've been whiling away the lockdown planning my new anchoring system. I was interested in whether I can downsize slightly to 7mm, high test chain from 8mm.
I've run just about every rule of thumb available. If I use Nigel Calder's approach, I get this for my proposed rode :
Load at 42knts wind speed : 598kg
Working load limit (wll) 7mm high test chain : 765kg
Wll 12mm anchor plait : 825kg
Wll Shackle : 750kg
Wll Kong 6-8mm swivel : 625kg
Which suggests that the set up is fine but that no benefit is gained by 8mm chain / 14mm rope as the same swivel would be used & it has the lower rating.
We also conclude that, whilst the swivel is great for most situations, in a manure / fan experience, removing the swivel would be advantageous. Working the numbers, that might increase the acceptable wind speed by 4knts to 46knts.
For higher wind speeds, our back up rode of 14mm/8mm with no swivel (which won't go through a winch) might be expected to cope with winds to 49knts.
After that ..........!
P.s. we are coastal cruisers and not expecting to endure an exposed anchorage in high wind speeds.
Wll Shackle : 750kg
