BrendanS
Yus. We should be grateful for 'em....
... for otherwise, we'd just have Viago, Brendan and Webby.
[/QUOTE
explain? crunt
[/QUOTE
explain? crunt
*runt
All this thread has done has added confusion and put me off buying a new anchor.
I absolutely do need a new anchor, as my current one is undersized and I have dragged on more than one occasion.
All this bickering has been incredibly unhelpful, with participants ignoring genuine questions about the subject.
Geem made this pertinent comment on the Vulcan - seagrass thread, Post number 55
'With all this talk about Mantus I decided to watch the Matus introduction video of their anchors setting. I was suprised to see how long it took for the Mantus to set. It drags along for some distance before it sets. I guss if it has a shallower angle then its dive to a full set takes longer. In my experience both Spade and Rocna set repeatedly within their own length. Something is different about the Mantus and it appears to be the shallower fluke angle. I have no way of knowing how good the anchor is as it hasnt appeared in any tests against its rivals so guess what? I just bought a new Spade. Not oversized. Its the same weight as the last one and selected straight off the Spade selection chart for the weight of our boat as the last one was several years ago'
At least someone took the trouble to, understand, look and analyse
Look at any video of a Mantus and it takes a long time to set - and if you check some of the (promotional) videos the videos are terminated with the anchor still moving.
With a shallow setting angle the anchor will take, in the case of a 16 degree trajectory in comparison with a 30 degree trajectory, of anchors of a similar size twice the distance to set. So the idea the Mantus anchor sets quickly is - well rubbish (or being kind - misleading. Simple geometry will prove the issue.
Of course if you are using a large anchor this will not hold true.
For example a 49' yacht might be recommended by Rocna to use a 33kg anchor. If you choose to use a much larger one, say 60kg, your auxiliary engine will set the Rocna quite deeply but the bigger (16 degree) anchor will lock up as quickly - because you do not have engine power to pull it more deeply into the seabed. The question then is would you rather have shallow set anchor in the low sheer strength surface seabed or a deep set anchor....?
The idea of Mantus setting quickly needs some qualification, which along with the omission of mention of the unique setting angle and the strange idea of how one defines ballast should increasingly raise questions. What is also strange is that regular criticisms of, say, Kobra is common (though not used by the individual), despite members here being happy with its performance but a barrage of complaint develops when objective criticism is made of Mantus.
Anchors are a safety item, they secure valuable bits of kit (and owners valuables , wife and children). I don't understand the defense of the indefensible.
Jonathan
LOL
What a lonely sad life having to apply yourself to your anti-Mantus crusade.
