Anchor Light
celtic_mist
21 Mar 2007
Éire
Just Checking All The Nav Lights Were Working Before I Head Away For The Holidays & The Anchor Light Was Not .
Got Out The Multimeter & Found Power At The Light Fitting ,
But When The Bulb Is In Place & I Turn On The Switch The Power Seems Too Disappear !
Any Ideas To Why Its Not Working ?
volvopaul
1 Apr 2007
midlands
hotmail.co.uk
The voltage reading at the holder without the bulb is only enough to give a reading to the meter, if you fit the bulb then read it you will see a great reduction if nothing at all, always test a light fitting or supply to a motor etc with a test bulb over 5 watts that way you can see whats going on in the rest of the circuit.
Check for corrosion on all terminals leading up to the holder.
brianrunyard
30 May 2001
Poole, Dorset. UK
homepage.ntlworld.com
There's a high resistance joint somewhere between the supply and the lamp holder.
As soon as you put the bulb in, the current drawn through the high resistance causes a high volt drop across the resistance.
Check, clean and tighten all connections.
