Neeves
Thanks Dom for the clarification, I'm surprised (and glad to be educated and my ideas found wanting). Its good to learn ones assumptions are wrong. Like Greeny I'd like to see some data. In the absence of data - I will be more cautious.
I'd add - my whole idea of using a decent snubber is to reduce the shock loads. Others, and sadly many, simply use a snubber to take the tension off the windlass which is admirable - but a short piece of rope will protect the windlass but do nothing else. A long, and importantly, elastic, think nylon (better dynamic climbing rope) will offer protection to the windlass and will tame shock loads. If you are taming shock loads the reduction in strength (say 25% - so now our chosen rode of 14mm anchor plait has a UTS of 3t (not the 4t specified) and the WLL has reduced from 1t to 750kg is not a major issue - because if you have removed the shock loads (they are taken within the snubber) then they will be a few 100kg (at most) and no-where near the 750kg 'limit'. I am assuming (sorry I keep making assumptions
) the use of the rolling hitch only produces a temporary loss in strength and that it is not permanent.
This raises another issue - you should not use a long elastic snubber alone, by itself (perfectly happy if you are alone
but much more fun if there are tow of you ). The snubber needs a back up - some form of chain lock (we use a short dyneema strop and a chain hook, if it were a mixed rode then another rolling hitch is needed attached to a strong point). Snubbers are consumables, like sails or anchor chain - it will wear out and if you do not replace frequently/occasionally it will fail with a sound like gunshot (so you will not miss the failure). You don't wan the tension suddenly transferred to the windlass - so use a back up.
But returning to the deleterious impact of the rolling hitch (and prussic knot) there needs to be another idea for attaching a snubber to a mixed rode. As though I minimise the dangers I'm all for maintaining the integrity of any item of equipment.
I'm also keen to see the data.
Jonathan
Jonathan
