arh
Hi all
Christy a hylas 44 is around 14 tonnes, the present anchor set up (which is as purchased) is:
30 kg stainless steel delta anchor
70 metres of 10mm chain galvanised which needs replacement due to excess corrosion
Windless which is broken and needs replacement
Future use is long term liveaboard. Given that the chain and windless need replacing (so can match any chain) what would the learned formites select ..
Stainless chain 8 MM. duplex or 10mm .?
Galvanised chain 8 MM grade 70 or 10mm grade 40 ?
Length ? 70m X 10mm or 90m X 8mm for the same weight ?
Without consideration of cost .. What would you pick ?
Would you keep or change the existing anchor, and if change the what too ?
Very open ended I know .. But really don't know or can decide the way forward
Tony
Tony
