MapisM
My chief mate (AKA swmbo) is in the process of recovering from a foot fracture, and in the check she just made, the doctor advised to avoid making any efforts on it for some time.
This got me thinking again about half an idea which was already swirling around in my head since I bought the new to me boat: adding some mean of controlling remotely the sticks and the thrusters, in order to be able to help with the lines while maneuvering.
The boat has mechanical levers (separate, two for each engine). The gear levers works by pushing/pulling steel cables directly connected to the inverters. A very simple and straightforward system, which I actually like more than electronic levers, but let's not go into that - each to their own.
Yacht Controller (and other similar systems) work on the principle of interfacing a receiver to the control unit of electronic throttles, hence making it possible to command the gearbox actuators of the electronic throttles from a remote, rather than from the fixed stations. But I neither like the complications nor the costs of converting to electronic throttles just for the sake of adding a remote control.
So, I was wondering if there is such thing as some sort of 24V actuator that can be attached directly to the gearbox lever, moving it in its three positions as if it would be pushed/pulled by the steel cable.
I suppose that if such thing exists, in principle it should be just a matter of attaching it securely to the gearbox and make it remotely controllable. Adding the thrusters control with the same remote shouldn't be a big deal, either (just a matter of electrical contacts, which I guess a simple relais can handle).
Obviously, I don't need any remote control of throttles - the thing would be strictly meant for maneuvering.
Coming to think of it, as I recall also the Yacht Controller doesn't control throttle, in fact...
Wadduthink guys, is it silly to even think about this, or what?
