geem
I don't disagree. The point of my post is that many people are not up to the job of converting to lithium. You only have to read some of the posts on the lithium forums to realise how many numpties there are out there dabbling with stuff they know little about. No wonder insurance companies are twitchy about lithium. Its not the cells that is the issue but the way many are installed.You're almost making me homesick
I was in the same position as you, I couldn't afford to put in Trojan 105 batteries, it would have cost me £790 delivered to address. My cells and BMS were £407. It's a big saving, for batteries that should have a far longer lifespan, without monthly maintenance, etc. A no brainer really.
Can we put to bed the idea that lithium is the expensive option?
There are people like you and me and Migs who can do it. There are many that can't.
Interestingly, I asked on the DIY solar forum how many cycles people had done with their lithium battery installs. Nobody had done thousands and only a very small number had done hundreds. Most were still below 100 cycles. I wonder how many lithium batteries will make several thousand cycles in their lifetime? I am up to 27 cycles in 98 days.
I know of 3 installations where they are on their second set of batteries in under 10 years. I think misuse killed one set. Heat killed another. Not sure about the third set
