DanLXIX
Active Member
I've recently fitted a KUS ammeter to be able to see the alternator charge, but for the life of me I can't work out why it's reading what it does. Turning on the ignition, it reads 0A as you would expect, but once the engine is running it just shows -80A. I've checked the voltages on the shunt and the sensor output is about 0.5v which tallies with it reading max consumption, but the voltage on the battery is 14v so it's clearly getting a charge. The wiring diagram below shows how things are set up, and I get the same reading from the ammeter whether I turn the DC-DC on or off. The shunt is installed as per the instructions so it's the first thing after the cutoff switch on the starter battery. Any clues to this would be very welcome.
