Duggy
Long-time lurker, first time poster.... (in fact, I have just realised I am coming on for 20 years using this forum and this is my first post!).
So - I am one year into owning my 2004 Beneteau Oceanis 331, which I am thoroughly pleased with. I keep the boat on a mid-river pontoon without shore power and I find myself in a constant state of worry that I will drain the two 100ah lead-acid batteries it came with if I spend any amount of time on the boat without running the engine (which I prefer to do only under load when I am actually out). I have no solar currently and no other means for generating power.
As a result, I have been buying various power upgrades over the last few months that I plan to install now I am on the hard over winter, including a 300ah Fogstar LiFePO4 battery, a Victron EasyPlus inverter/charger, various eye wateringly expensive tinned cables, busbars, solar panel, MPPT controller etc...
As per the thread title, I was just on the verge of puchasing a Victron 30a DC DC charger (so I could safely get some charge into the new house LiFePO4 battery from the engine when out and about), which I had sized based on it being 50% of the rated 60a output of the factory alternator that comes with the VP MD2030. However, it has occured to me that my 20 year old alternator is probably not as effective as it once was and since even new alternators are unlikely to generate more than 90% of their max rated amps at high revs, I am guessing that my alternator will have diminished somewhat over time and may be generating much less than 60a these days. How critical is this likely to be? Is this even an issue I need to be concerned about?
Obviously, I do not want to burn out the alternator if there is still some life left in it, but I am hesitant to downgrade to the Victron 18a DC DC charger and reduce my potential LiFePO4 charge rate, particularly if I find myself needed to replace the alteranator anyway at some point in the future.
Any advice/suggestions would be welcomed.
