Planing, for that waterline length and speed, you must be planing.
That is a planing hull, it doesn't matter how big your engines are, if you dont have enough power to make your hull plane, that's a different matter, planing hulls will travel at displacement speeds, often very uncomfortably and often not very directionally stable.
That is with the tabs half down!
I'm more than happy with the way she goes through the water, its just that talking to various people they have different views on it and the manual doesnt really say. Its a very deep vee at the bow and also deep vee at the stern with a piece that protrudes from the stern by about a foot down both sides of the hull (that the tabs are attached to) but with a gap of about a foot across the bottom.
Agree with you ccscott49. IMHO there's no such thing as semi displacement although I use the term myself. If a hull is going faster than it's max hull speed, then ergo it must be planing. Really what semi displacement means is a hull that does'nt lift out of the water as much as a full planing hull but they both plane
I am pretty sure you have a semi displacement hull. I have always understood that to be a planing hull it has to have chines the full length of the hull or at least 2 thirds of the hull. No one here has mentioned "Chines" they are the ribs that run the length of the hull and help force the water away from the hull thus creating the lift that a boat needs to plane properly. S.D and Displacemnt hull are usually smooth and often have a small keel as well, often a S.D. hulls can perform with speeds around 20 knots but don't normally really get up and out of the water so don't usually exceed 20 odd knots.
Technically, there is no such thing as semi-D. All hulls have the capability of becoming planing. Its just that some hulls become downright dangerous when you plane them - ask any yachtsman who has surfed down a large wave in a storm.
A boat makes two wakes - one off the bow and another off the stern. When you cause your hull to overtake the bow wave, you are planing. So when you see your bow wave disappear off and you get only one wave out from the stern, you have your answer /forums/images/graemlins/smile.gif Your lower picture would indicate to me that you are planing even though there is some splash off the bow which is quite normal.
.A.E., however, recognizes that not all owners or prospective buyers need the incredible range of these passagemakers and instead would prefer to go a bit faster during their coastal cruising. A sensible, pragmatic approach to providing faster speeds without sacrificing seaworthiness is to design a boat with semi-displacement characteristics. This design allows the hull to get partly out of the water when sufficient horsepower is applied and to get out from the grip and limitations of its own bow wave. The boat essentially begins to "plane."
