sewardsfolly
My yacht, a Neptune 16, has a leaded centerboard which has bloated up for the second time, jamming in the trunk; aluminum/lead electrolysis.
I have pulled it off and cleaned off most of the white oxidation that pushed the lead away from the aluminum blade and plan to seal the aluminum blade with epoxy , epoxy two segments of lead back onto the blade and wrap it well with fiberglass. The goal is to isolate the two metal connection from any electrolyte (salt water). My question is: if limited residue of oxidation is enclosed and isolated from oxygen and electrolyte, will that oxidation give birth to more oxidation within this closed system which has no electrolyte. I ponder this because I have learned that once you have iron rust it is self feeding and will continue in a closed system even without access to additional oxygen or elements.
This will be my second attempt to fix this. In my first fix, I thought that I had closed off/sealed the bi-metal contact from additional electrolyte, but somehow the bloating/battery electrolysis happened again. This second time, I went ahead and tore the "liberated" lead from the main body and I have been able to clean out most (99%) of white oxidation but tiny amount remain. Will it be OK to seal this away from air /oxygen and salt water?
I want to upload images but cannot figure out how to do that.
Thank you for your expertise!
