Aluminium Toerail hand cutting tool?
UK-WOOZY
7 Feb 2015
Originally Erith YC, now River Medway
Aluminium Toerail. What is the best hand tool to use as i have no access to a mitre or band saw, would an angle grinder or hacksaw cut it?
attached is a pic of the rail of which i have a 6m lenth of at home i want to cut a 1 metre length from.
thanks all.
Stemar
12 Sep 2001
A hacksaw with a decent 24 tooth blade and if you are concerned about the cut a cheap and simple mitre block is your friend and guide. If you go the angle grinder route get the correct disc for aluminium.
This. You'll get a more accurate cut than with an angle grinder. If you do use the grinder, cut a couple of mm on the waste side and sneak up on the line, rather than trying to do an accurate cut.
Fr J Hackett
26 Dec 2001
Saou
thanks for the input all. i ordered this to pickup tonight at screwfix
OX Pro 24tpi Wood/Metal/Plastic Hacksaw 12" (300mm)
upercove Plastic Mitre Box
If as seems the case you are unfamiliar with a hacksaw, like all saws the mantra is let the saw do the work, do not force it or be heavy handed just slow cuts using as much of the blade as possible without the frame hitting the work or the mitre box.
Apologies if I am teaching my grandmother to suck eggs.
