alteredoutlook
I have an aluminium boat with integral water tanks. Some time in its past it must have had some foreign objects within the water tank and the result is corrosion pitting at the bottom.
The plate is 6 mm thick and the pitting is up to 3 to 4 mm deep in places. Thus, another 2mm and sea water will enter. The problem is not structural.
What can I do to a) fill the pitting b) prevent re-occurrence.
Suggestions made so far include
a) replace the plates completely
b) apply another layer of plates to the outside of the boat
c) weld the pitts – a bit difficult as limited access – and can it be done with aluminium?
d) Apply epoxy to the bottom of the tanks. Does a non toxic one exist?. Would I have to paint over the epoxy to seal it? Will epoxy ‘stick’ to the alumiunium? Does a clear epoxy exist so that I can see if the problem is still happening.
e) Apply a layer of cement to the insides of the tank. Will it crack/flex off? What sort of cement do I use?
Any other ideas or suggestions on how to do the above will be appreciated.
