BruceK
I've been running on LifePo4 for a year now on our Sealine S37. we have 560AH Lifepo4 (8 individual cells in a 2P4s configuration) with a Rec external BMS, Balmar 100A alternators on Volvo Kad44 (single V) running through Wakespeed WS500 regulators and all controlled via CAN bus and Victron.
I wish there was a way to run a serpentine belt on the alternators on the Kads coz then you could use a much bigger alternators
Lithium is amazing you won't go back to lead once you have tried it.
regarding charging options you either have to go down the DC-DC charger route which wont get you many amps or external regulators
we did run of the standard volvo alternator for a while until i got the Balmar's though if hindsight and if i do it again i would probably go with Lece Nevile alternators next time as Balmar are a rip off..
let me know if u have any questions
Fantastic. Yes I will shortly. I'm currently looking at a MasterVolt drop in solution including alternator but the alternator may have to be adapted to fit. Let me have a look at this Lece Nevile and I'll come back with a job lot of questions.
