John100156
Mmmmm I do not think it would double the current flow but I think we are generally in synch. The actual voltage drop for say 2x100AH batteries losing 10AH each (90% charged) compared with a 1x100AH battery losing 20AH (80% charged) is not that great, see graph below:
Also the alternator regulator being voltage sensing, which of course governs its output (current flow), would still tend to quickly limit the current flow at these voltages after the initial surge.
The area under the curve (lowest graph) indicating the actual AH put back into a battery set given a 20AH (30A for 40mins) load:
I just think the amount of increase in current flow would not be sustained and as great as you suggest, because the current flow from the alternator regulator is also non-linnear and the voltage sensing capability of the regulator is quite good (hence alternators increase OP when they detect load fluctuations switched in/out).
Of course the true characteristics of the load would need to be carefully considered if we were to do justice to this debate! Be interesting to rig this up on a bench! /forums/images/graemlins/ooo.gif
This kind of problem led to the development of smart chargers which if we want to keep our batteries as near to 100% as possible must be the better option!
Good to bounce this around..... /forums/images/graemlins/cool.gif
