mjm
I am having a bit of trouble with my Yanmar 3GM30F. I went out one day for a sail & could not start the engine I have a flat battery I did managed to start the engine by jumping it from the domestic batteries. Then I noticed that the engine was not charging the batteries at all. I put a meter on the alternator there was no current at all. When I was doing this I notice that a wire that was connected to a plug in the back of the alternator was not connected i think this was the D+ line. So I took the alternator off & re-connected the wire back in to the plug at the same time I also re-connect the other wire on the plug as well. When I put the alternator back I started the engine & tested the voltage again & there was no current I then pulled the plug off the alternator & have a 12.4v current. So either the alternator is not working or could it be that I re-wired the plug the wrong way. Can any one help what happens if I swap the wires on the plug or any thing else I can do.
Mike
<hr width=100% size=1>
Mike
