DHV90
With the engine not running, the WL terminal should be low voltage, the light should be on.
First thing to check is the brushes.
Then check the bulb/holder/wiring, you've really already done this by seeing battery volts at the WL terminal.
From what I can see on the web, the field coil is connected to the diode pack and is energised by pulling current out of the F terminal on the alternator. So a low voltage here suggests the alternator is the problem not the regulator.
Amazing thanks, this is really helpful sorry for taking up so much of your time.
Does this mean that I, in theory, should see a voltage at the F terminal on the alternator when the field cable is disconnected?
So the power to excite the coils probably comes from the alternator diode pack, through the regulator and out to the F terminal on the alt? Getting switched by the WL circuit but not directly linked?
To check the brushes is resistance between F and alternator body/earth the correct test?
Thanks again all this help is much appreciated
Edit:
Just realised that the brush box is it's own plastic unit with terminals on the top. Should one of these terminals be led to earth? The way the PO installed this has the armature wire from the regulator going to one of the terminals on the brush box, with continuity between A and F. Could this be wrong?
I couldn't see any other terminals on the alternator that A should connect to but the access is too tight to see if there are any markings on the brush box for which terminal is which
