TernVI
Try connecting the correct rating of bulb directly from the B+ of the alternator to the WL terminal.
If it works wired directly but not through the spaghetti, then the spaghetti is the problem.
If it doesn't work directly then your alternator is sick, it's unlikely to get better, quite likely to get worse or die.
Adding resistors which were not originally needed and should not be needed now is a sticking plaster for a terminal illness.
But it can help diagnosis. And it can allow the use of LED bulbs.
Better to measure the current going into the WL terminal (engine not running) and see if it's fairly consistent with the bulb rating.
The WL terminal will be a bit above 0V, so a nominal 2W bulb might only give 150mA or something, but a good alternator should excite with a margin for low battery.
But first check that with the light on, it has 12V on it and that the body or -ve terminal of the alternator is 0V relative to the battery.
Bad earths mess up diagnosis!
