Cardo
So, our current setup has the 60A alternator going into a split charge diode and then off to the engine and domestic battery banks. Needless to say, the domestic bank charging is pitiful, even when motoring along at a hefty set of revs.
So, some kind of device is required to keep us juiced up.
There seem to be two main types -
An advanced regulator, such as this one:
http://www.marinesuperstore.com/item/07519/sterling-alternator-regulator-pro-digital
Or this fancy A2B charger:
http://www.marinesuperstore.com/item/99197766/sterling-alternator-to-battery-charger
Now, aside from the £110 price difference, what is the actual difference between them at the end of the day?
My skills with soldering irons and stuff are good enough to fettle, so installation isn't a concern.
The advanced regulator only has one output, which then needs to go to a split charge diode. The A2B has two separate outputs. How can the former bulk charge the domestic bank whilst only applying a float voltage to the very little discharged engine battery?
If you were in my position, which would you go for?
