PaulRainbow
That's interesting Paul. My combination of simple alternators (one 80A alternator on each engine) and 400W of solar through the Victron MPPT do not behave like that.
With mine, if I'm on solar alone and the solar has reached float voltage on it's own and I start the engines, then the engine alternators will put out just 5 amps or so.
If the solar panels alone have not reached float voltage but are still on the bulk stage they will be showing perhaps 10A going into the batteries at say 12V or 12.5V. If I then start the engines, the alternators totally take over the charging regime and both alternators will start putting 40A to 70A into the batteries which will be 80A - 140A if I'm running both engines. The alternators will then run the whole show until the battery voltages rise to over 14V and the Victron kicks into float.
Once I start the engine/s I can leave the solar panels connected or not .... it doesn't make any difference because the panels just throw in the towel as soon as the "big boys" join the party.
Richard
I'm finding that happens when i turn my mains charger on Richard, the solar controller just shuts down. It's all about where the various charger set points are. Your alternators are obviously set to a higher voltage than mine, so they "over rule" the solar controller. Mine is lower than the solar controller, so the solar controller is King.
Mine works fine for me. If i needed to make more use of the alternator output i'd make some changes there, but for me it'd be a waste of time and money.
The OP has a big alternator, a small solar panel and motors enough for the lack of alternator output to concern him. So, it's important for him to get as much from the alternator as he can.
