ianc1200
Last year I had a brand new Yanmar 2YM15 installed in my Crabber, at the same time two new leisure type batteries.
At an early point I pressed the wrong button on the panel & the engine ran briefly without the electrics on.
Some time later, concerned whether I had damaged the alternator, I thought I saw a 14.9V reading on the engine panel, but this didn't occur again.
The batteries have a 0/1/2/both rotary type switch, and being new to me, I mistakenly was running the engine charging the starter battery only, but not charging the domestic.
I realised this whilst on holiday when the chartplotter failed to work - we rarely use the internal lights, and their being no other draw than echo/VHF/chartplotter.
Having realised the mistake, I checked the domestic battery with a digital voltmeter, and found barely 6V.
However, the battery charged back up, and later in the season the engine would start via this domestic battery on it's own after not being used for several weeks.
I noticed early in the autumn when charged up at home the domestic would quickly get to 14.9V, and assuming it was it poor condition, I bought another. Yesterday I charged the starter battery on the home Halfords charger (having done so several times during the winter & OK), it too quickly got to 14.9. Both the old domestic and the starter have lost the green tinge to the viewing eye which I understands is an indication of being in good condition. (both had it though at the end of the season).
I intend buying another starter battery, but the question is whether the alternator could be damaged?
Should I run the engines, with the two new batteries, and if the panel reading goes above 14.5V have the alternator checked out?
Or should I take a reading off the output again to check whether too high?
The boat is out of the water for a few more weeks, I'm wondering whether it should be removed for checking in any case.
Any views welcomed, and thanks for reading a long post.
