killick
Sometime ago I raised the problem of my rebuild altenator charging at 15 to 15.6 volts. The general consences was that as long as it is charging only for short periods no harm will be done and that I should check the electrolite level in the batteries on a regular basis. This I have done and experienced no problems. The other day I ran the engine under load on the pontoon for about 30 minutes charging both batteries . Checking the batteries some 20 minutes later I found one cell in the starter battery boilling and both 15 amp fuses connecting the barreries to the solar panel regulator blown. The batteries are 50 amp Exides and appear to be normal lead acid. The dealer says it is lead calcium but I cannot find any indication of this on the batteries. Any asisstancs will be greatly appreciated. I am removing the altenator to have it bench tested.
