MagicalArmchair
Yesterday was the first time we got out properly on Triola (where does the year (and the flipping season) go), ho hum. I noted the shrouds were somewhat loose, and on inspection when looking up the mast when she was creaming along upwind there was a bend in the mast above the lowers to leeward. I had tightened up the backstay before our departure (as that had to be taken off to lift her in some months ago), and I have a backstay tensioner on there too, however, even the forestay with its roller furling Jib in the luff groove on it was bowing out.
The mast still has the requisite rake to aft that sets the sails nicely and has her storming along to windward, I just want to make sure she is set up correctly, and most importantly, the pointy bit stays pointing upwards!
My planned approach is take out the split pins on the shrouds and crank them tighter, then go sailing again and have a look up my mast and make sure she isn't going all banana like again. I'll likely do the same on the forestay. Any words of wisdom for doing this 'right'? Anyone know what the rig tension should be of a 1970s Albin Ballad? I would prefer to avoid the expense of getting a rigger in (and besides, I like learning and doing this stuff myself).
