beneteau_305_553
When laminating hulls the gell coat is painted onto the mould usually with a brush leaving an uneven surface. If air bubbles are trapped between the first laminate layer and this gel coat which is semi permiable, when the temperature in the void falls, a lower pressure exists in the void. Moisture then gets pulled into the void.
When the temperature rises, as air is easier to expell than water, air is expelled and any condensation in the void remains.
Repeat many times and the bubble ends up full of water.
Then when a temperature change occurs the pressure in the void becomes very high because water is non compressible.
This pressure then expands the void and results in a bubble of water between the gel coat and the laminate.
Perhaps we should be eliminating air pockets between the gel coat and the laminates during moulding as well as using isopthalic resins?
<hr width=100% size=1>Richard
