Seastoke
Does anyone know who is the importer, I am trying to buy the o rings .
Hi roughly got mine at about 150 mm diameter , are yours AG cheers BB.Picture won’t load. To large a file
Thanks but wrong , they are not o rings.
I’m quoting from the Simply Bearings site as that’s who I use for all of this kind of component. Nitrile O rings are all that’s needed for cooling water. The internal diameter is 147mm so 4 mm thickness gives an outside diameter of 155mm. O rings are ordered on their inside diameter and thickness
Thanks I could not see the maths , thanks a gain it’s saved me money and time.147mm ID plus 8mm to give you OD if using a 4 mm section o ring
