iainzxr
Active Member
A question for the more knowledgeable on electrics. I'm planning fitting a used Aerogen ... small one I think ... to my boat. At present it is fitted on to my garden fence so that I can check that it is working ok. So .. it's spinning round like a banshee and when I connect my multimeter to the 2 wires it reads up to 19 volts depending on the gusts. So what can I expect to get into my battery going through a regulator ... ie can you measure amps or whatever from this .... or how does one work this out. Also, by joining the 2 wires the blades slow right down ... as I've seen this on other posts. Is this the right way to slow it down through an "on and off" switch.
