BruceK
KAD 42
Background- may be related
A few weeks ago on a cruise port engine outdrive lost it's rear prop. Were C4's.
C4's not immediately available replaced all 4 props with equivalent B5's
Continued on cruise all is fine maybe a slight decrease in revs for cruising speed from 3200 to 3050 for same speed.
Filled up with fuel from a new marina / source
Got onto plane effortlessly and performed well. I was delighted.
First instance
Coming back to home port cruising in hot ambient temps engines running 5C hotter.
Got onto plane easily enough and covered 15 mile before I thought a small single engined aeroplane was buzzing me. That was the noise. Small single engined prop tip buzz/boom. Not quite like a helicopter but there.
Engines went to 100.
Let the engines cool while at displacement speed and engine sounded just fine.
Boat struggled to get back on the plane (single engine aircraft prop noise gone and subsequently never returned. Was it my imagination? I heard it quite clearly but no one else seemed to) with supercharger bouncing in and out unless on kick down. It's the Starboard engine i.e. not the one that I lost the prop on originally. Symptoms have remained on subsequent 2 trips out. Engine now runs hot. Just shy of 100C. No loss in max rpm functionality. Engines will rev to ~3700rpm and sound good. Just a complete gutless midrange and quick over temp struggling to get off supercharger
More unusual behavior. In neutral I can rev the starboard engine to max rpm. However when coming off the throttles slowly, when the engine reaches ~2600rpm and the super charger kicks in (reverse sequence here) the revs immediately drop to ~2200 rpm as if the super charger is tight and loading the engine. It is not though. It can be easily and freely turned by hand.
I will be replacing exhaust elbow and thermostats this weekend to see if that cures the temp issue. Raw water pump is new and good changed this winter and cooling system was decalc-ed chemically with Rydlyme and will checking turbo for wear. What else could cause these symptoms and a loss of power in the mid range? I'm leaning towards turbo, but the symptoms came on awfully quickly to be turbo wear, I think.
First instance
