Advice on first family boat
chortle
20 May 2020
Hi everyone
I wonder if I could lean on some of you for some expert advice. I am looking for a first boat for our family of four (2 kids 9 and 11) - also small dog! The boat will be marina berthed and the max length allowed is 7.3m. We have a place very close to marina so won't usually overnight but I think something with a cabin would be good for cooler days and would definitely want heads( ideally enclosed and sea toilet not chemical). I have some experience (having grown up with small motor boats in the family and having done some yacht sailing also as an adult). Nevertheless, it needs to be easy to handle. It will be daytime use in good conditions only and inshore. We don't need high speed but a cruise of 20 knots or so would be good (I guess max 25-30 knots). Would like seating for six in the cockpit with a removable table and some sun/weather protection (good canopy or bimini).
Main uses will be cruising and day trips around the Western Solent and some light inshore fishing. We would like enough space for a couple of guests - so max would be probably 4 adults and 2 kids. (4 adults and 4 kids would be even better). We are looking now and I have narrowed to either a small cruiser (eg. Fairline Sprint, Sealine S220, Sea Ray 250 Weekender or newer equivalents) or one of the fast fisher types (eg Merry Fisher 645). If it is up to about £15k then I would probably buy outright. I would also consider up to £25k or so with some financing.
Cruisers
Having looked around a bit now, I can see the odd older cruiser (e.g. Sealine S220, Fairline Sprint from late 80s/early 90s). They look to be in the £10k-£15k range from a broker. These would just about fulfil the role - the Sprint and S220 look ok for a little fishing off the sides (some others are not so good). Condition very variable. Some look quite rough. All petrol sterndrives (some original or 'rebuilt', occasionally re-engined).I know these will be expensive to run but hours will be quite limited and mostly at cruise or trundling along. Main concern is hassle of things breaking and any associated safety risk. I do remember quite a few issues with our family Cleopatra 700 many years ago and I guess it was probably newer in those days than these boats are now (i.e. c. 30 years old now). Am I just asking for a heap of trouble here? Worries about old sterndrives, worn engines and worn ancillaries) but also hidden things like corroded tanks
There are also some newer small cruisers about (late 90s/early 2000s) - Sealine S24, Bayliner 2355 and other American boats. In value these go from high teens to mid 20s. Fancier cockpits (actually maybe worse for fishing because of that - the 2355 looks really difficult for fishing at all although otherwise looks good). At these prices, I am not sure whether they would be eligible for a marine mortgage due to age. Maybe these would be more reliabl than the older boats e but they are still c. 20 years old.
I know these will all be expensive to run and are a bit wayward at low speeds. I also understand the quality differences between the brands. I would get survey and an engineers reports on any of these.
Sports fishers
There are lots of these but a sweet spot seems to be something like a Merryfisher 655 . Has enclosed heads and a reasonable cockpit plus good outside space with seating and good fishing platform. Shaft diesel semi-displacement with cruising at maybe 15 knots/max 22 knots. On the face of it these seem like a good option in mid 20s with finance (they are about 10-15 years old and look simpler and less to go wrong. Inboard diesel and shaft also seem a less risky prospect. But I have no experience of these. Would they be much noisier. What is the handling like - I guess much better at low speeds and more stable at anchor but a bit more wallow and wet underway? Also the separate wheel house thing is new to me and I am not sure if that's family friendly or not. I guess plusses and minuses. Presumably easier to finance as newer.
Am in analysis paralysis now and some outside help would be good. Actually am leaning slightly to the unknown - ie the merry fisher option. We are busy and won't be able to do lots of work on a boat ourselves. I think the maintenance costs on the cruisers might be prohibitive and the MF might be also more practical in other ways. The canopy seems much nicer for instance. Also I think I will end up doing a lot of the docking/anchoring and mooring single handed (or close). The cruisers looks tricky when moving forward to anchor or secure fenders (on the other hand you are not in an enclosed wheelhouse)
Would be interested also to understand the likely trade off in fuel economy at cruise between a c. 200hp sterndrive petrol and a 115hp diesel. (I know the cruise will be 20% faster on the petrol boats but I guess that is also offset by the higher price of the fuel). Also the noise from the engine. Will a diesel inboard be as noisy as some of the older boats I have been on (not that a petrol inboard is necessarily that quiet at speed). Most importantly I want this to be safe, fun and comfortable. Your advice on all/any matters will be gratefully received. Although I am not a novice, I will seek to do the Poweboat Level 2 and also VHF (as a refresher and to cover any gaps). Also will make sure all safety equipment in place (flares, life jackets, first aid etc). Back in the day we had an auxiliary outboard on a bracket but most seem not have that facility. Is this no longer the practice? I know there is an AA type service "Seastart" - maybe that is the way to go?
Thanks to all again
Hi
Good small cruiser that will not break the bank, single deisel engine and good in the Solent sea chop is the Sealine S23 or S25. Cruises at 20 -22 knots cheap to run with a KAD 32 at 170 HP on Duo prop. Older Sealines are available but they tend to have petrol engines mostly at this size. The newer one was and remains a great package, when or if you trade up or sell up you will not blow your brains out which is always a positive, great first cruiser. The older ones are more dated but Sealine has always produced a good UK boat and would fit the 7.5 metre bill and is trailerable with a big 4 x 4. They do tend to be around 29K but offers are always welcome !
Have fun looking and have an engine survey minimium on anything you buy, it could save you alot in the long run.
Thanks both
No easy answers. Will be checking out both types next week including an S23 diesel, an older Sealine (petrol) , a Merry Fisher (diesel inboard) and another similar boat with petrol outboard.Actually the Merry Fisher looks really good but concerned about the noise....
will let you know how I get on.
Thanks for the feedback. We are looking at a few different boats next week including a couple of the Merry Fisher type, a couple of early 90s cruisers and a slightly newer Cuddy cruiser to see what looks best - they range in price from c 12k to c 25k, so there is a bit of a range there. Will be interesting
Sprint not big enough, 4 adults has the swim platffrm kissing the water, though I am told it will still get on the plane, and that was with a VP 4.3GLJ 190bhp engine and SXA sterndrive.
The inboard petrol V6 and V8s drink their fuel, even when pottering along.
May I add from my experience some years ago, if you get one with an outboard, get something with a trailer, as to service an outboard of reasonable size and power the boat needs to be out of the water and if you have to pay someone to lift it out.......ouch! Some years back we had a MF 625 with the 115 hp outboard and the service cost £400 + ......and the liftout/back in again was another £230, with the engine service done in the slings, 1.5 hours, double ouch!! We found this out after we had bought it.......
That is very interesting. We are looking at a Sprint, a Sealine S220, a MF655 (inboard diesel), a late model Sea Ray S215 Express and some others that I am trying to line up. We will be on a marina berth and so the trailer is probably out. Actually it is hard to find a boat with an outboard that has enclosed heads in this budget. The MF695 looks great but way more expensive.
have you any idea how much service costs on stern drives and engine
I’m guessing something like £750 a year. Maybe that’s under. Expensive, especially with the fuel costs on a carb v8.
I would have thought diesel shaft would be half of that and petrol outboard somewhere in between?
i see from pics on the sea raysome corrosion at the join between the manifolds and risers - so guessing those would need renewing for that one.
Am I miles out on this?
Yes. It seems like this type works and I am working through the variations across the different sub brands. At under 7.3m with seated deck space for 4-6 people it looks like mf 645 or 655 or Antares 6.8. The first and third are outboard, which from this thread seems to be preferred. But neither have enclosed heads. Also I like the saloon table in the wheelhouse on these two.
The 655 has the enclosed heads but a two abreast helm without the table and is inboard (so noisier and slower I guess).
short of the series 2 695, you can’t do the best of all 3 (and those look like 60k!).
You speak of up to eight people,Firstly you need to check the C.E cert for no of people and trappings
More than six people on these types of boats you mention is going to be uncomfortable.
Having owned si.ilar size for 25yrs I would def go shaft drive and fit better insulation which makes a huge difference
Right. I’ve been looking at that. The 7m ones - MF 705 are approved for 8. The 655 is for 7. Same for Antares equivalents. Thanks for the feedback on noise proofing - I was wondering about that and it makes total sense. The speed differential is not an issue for us actually. I think it will be 4 people usually, with 6 sometimes and 7/8 extremely rarely
Subject to passenger restrictions - the Antares 6..8 looks good if you can live without enclosed heads (I think we would prefer that though). The layout looks better than the 645. After that it looks like inboard with mf655 or 705.
having looked at them now, cruisers look less appealling for our use. The newer ones would be priced similarly (and are still pretty old and costly to run being petrol, stern drive or both).
I am not sure that the older ones - eg S220 or Sprint would be reliable enough or would actually accommodate 6 people ( which would I guess be the sensible limit for either) although certainly a good but cheaper.
I've have a 2010 MF 645 with a 115hp Suzuki outboard. My thoughts:
Very good boat for 4 people for day trips, any more and it can feel a little cramped, No enclosed heads (porta potty only)
Build wise its functional (built to a price) so not what you would call a quality fit out but not bad. For the size its very well designed, very little wasted space and very easy to keep clean.
Speed wise its either 6kts or 22kts, at 6kts it uses very little fuel. For a good day out i use about £35 in petrol (depending on how far i go)
Engine service is £400 a year, lift out is £85 (each way) The big costs with boating is the mooring and in my marina you pay for at least 8mtrs even if your boat is smaller. This is typical btw. My boat is on a pontoon, you could drystack it which is slightly cheaper and a good option if you live some distance from the boat.
Every boat is a compromise tbh, what you think you will use it for often changes. Most of my days out are just pottering around Poole harbour with the odd trip out to Poole bay for some fishing.
Im based in Poole harbour and for the area and the sort of boating i do its hard to beat.
Unless you want to put her on a trailer, I'd go for 8m.
Here's our first season (last year) with our 8m Fairline Sunfury. 2 adults, 2 little kids and 2 big kids. However only have 2+2 really at any one time.
First season
We have a swing mooring for the summer and keep her ashore for the winter (6months). I doubt the UK winter would be too much fun in an 8m boat.
That keeps costs down ?
