silver-fox
Today my shorepower on board failed in the marina.
A quick check at the boat end of the shore power cable revealed all was well that far, 220v live with earth and Neutral Zero v.
Once connected to the boat the following readings were obtained:-
All devices switched off. L 229V N 61V E 0V
Under load (water heater or battery charger) L 229V N 229V E 0V.
All testing done at the distribution board on the shorepower feed.
The consumer end of the circuitry splits via 3 trip switches into ring main, water heater, battery charger. I get the same test result whichever option is picked to provide the load. From that I concluded the problem exists between the shorepower socket and the distribution board.
Between the shorepower socket and the distribution board is a single cable with an RCD which does not trip, (neither does the RCD on the Pontoon).
I am assuming I have got some sort of short between L and N, but if so why doesn't it trip the RCD? I have checked the terminal connections for loose wires etc but can find nothing amiss.
Any advice on how best to proceed gratefully received.
