Scubadoo
Looking for some advice/direction on resolving a 12volt electrical problem on my Sealine S24…..last weekend I discovered that the engine battery is leaking voltage to the domestic battery/circuit. The “leakage” seems to be no more than about 0.5amps (the boat domestic volt meter fluctuates 8 to 12v when switching on an led light), the problem occurs when I switch the engine battery key on and I leave the domestic battery key switched off.
I have already checked the “Battery link” solenoid by disconnecting, also removed the battery key panel and all looks okay and disconnected the bilge pump fuse. Looking at the Sealine wiring diagrams (which is not that helpful) I can’t see any other connections where the two batteries circuits could connect.
Anyone got any suggestions where I should look next or have experienced anything similar, any advice gratefully received. Failing that, anyone know of a good marine electrical engineer?
