Any advice or suggestions would be greatly appreciated on how to free a seized seacock on a boat which is curently back in the water.
The grey water outlet from the head was perfectly fine until I tighten a nut on what I can best describe as a plate holding in the valve, from which the lever is attached.( Are you with me ?). This I did because it was loose and the valve weeped. Once I found it had locked the seacock, which was almost immediately, I naturally lossened the nut, but the seacock remains locked. What now ?
