C
catalac08
hi
bought an "oak" front door 3 months ago - this is a Wickes Oak Door which is described as "veneered" engineered oak. I did some soul searching before buying but decided that it could not be a veeer in the traditional sense as this would be compltely unsuitable for an exterior doors and must be an external oak layer laminated onto ply. Anyway at £550 rather tha £800 took the plunge.
My initial instincts were to weatherproof using Deks Olje penetrating oil and then the sealer oat but the instructions with the door were to use only the Wickes Exterior Varnish (not to use penetrating type wood oils) so this is what I used - 4 coats outside and end grain and 3 coats inside.
After 3 months the door has swollen and I have twice cut back into the hinge recess to stop it jamming. The bottom joints outside are showing staining (blackening) showing water is getting in and one or two of the other joints also. To my surprise
inside the door is the same as the codensation on the door results in puddles in each of the panel beading recesses, and the joints inside are showing signs of water ingress and staining as well.
The door measures now 30 inches exact at the top, 301/8 inches at the centre and 303/16 inches at the bottom.
It looks as if the sealant system is failing not only at the joints but also on the flat surfaces although there is no discolouration anywhere else.
How do I retrieve the situation i.e. seal the wood properly now, cover or bleach the discoloured areas and get the door back to its correct size/dry it out, but not necessarily in that order. Would yacht varnish now stabalise the situation and stop it getting worse (with a view to taking off the door and drying it out in the future) or would it seal in the moisture - does varnish breathe?
The varnish that is on seems to have a sort of waxy feel rather than glassy hard like marine vanish, perhaps it is intended to be flexible at the panel joints?
I do not hold out much hope of any redress from the door supplie as it will be very difficult for me to prove how many coats of the recommended varish have been applied before the door was installed..
Any advice from wood experts is gratefully welcomed!
