AntarcticPilot
Yes and no, plot matching software has been around for a long time and can allow different standards to be overlaid even prioritising the best quality data.
If Taunton thought they could make more money by doing it they would but in reality they leave this to the chart plotter map suppliers who use their data.
Matching different standards and resolutions is fraught with problems; it CAN be done, but whether it SHOULD be done is another question!
If you feel like researching the problem more, look up discussions on generalization;there are many excellent specialized books. "How to Lie with Maps" by Monmonnier gives a good introduction, is easy to read and is regarded as required reading by all cartographers! However, the gist is as follows:
There is a limit to how much information can be represented on a screen or piece of paper, which depends on a) the limitations of the human eye and b) the resoluton of the medium.
People compiling maps therefore have to make decisions about what to represent and how to represent it to take account of this. There are several methodologies for doing this, including symbolization, aggregation and abstraction. ALL of these are scale dependent and in general, irreversible (you can go from more detailed to less detailed, but not the other way).
It gets a little more complex than that; in some cases generalization includes changing the actual concept being mapped; for example a detailed chart might show individual drying rocks, but a less detailed chart will show a reef - different conceptualizations of the same reality.
Therefore, overlaying charts compiled at different scales tends to be unwise unless it is done at the least detailed scale - which probably isn't what you want, and isn't usually necessary anyway.
Note, by the way, that the underlying chart data are not raster (as I think you are assuming), but vector, which makes the problem easier in some ways (positional information is explicitly held for every object), but harder in others because of the issues I skim over above. Basically, producing reliable charts that are centred on arbitrary points of interest requires a uniform map database at the most detailed resolution (ideally in vector form) for the entire area being covered. This isn't the case for charts.
PS, Chart plotters don't usually merge charts; they select appropriate charts according to the display scale. This is very different from the problem of creating charts centred on an arbitrary point of interest.
