flaming
Out of interest, is adjustable mast bend not required to vary sail fullness (camber) at the top of a fully battened sail? Relevant because OP has a masthead rig, while a number of replies are from those with fractional rigs.
Not really I think...
What bending the mast really does is flatten the middle of the sail and open the leach profile.
In general the reason full battened sails are great on cruising boats is because they provide bags of power and are very stable. Why they are not used on conventional racing boats is because they are very difficult to depower. This isn't such a big deal to the cruiser, you just drop a reef in. But racers are about to turn the corner and go downwind so want the full area available without all the power. Hence being able to flatten the sail is a much bigger priority.
For cruising I would absolutely always specify a fully battened sail.
For the OP.
My questions are: from a performance point of view, over variable wind strengths, does fully battened hold it's shape well? Do you still tweek halyard tension for camber position, or is it hard set by the full battens? Do you have to adjust batten tension or is it set when the sail is rigged. Can you change the depth of camber on a fully battened sail? Vectran is it the best way for a polyester sail longitivtiy before going to a laminate. Those who have changed from standard to full length battens and have done so for some time now, do you see performance maintained over a long period?
Camber profile (as distinct from amount) is still set with halyard tension. You can still use a cunningham to flatten the bottom section, but it has less effect than you are used to. Camber amount is largely preset with batten tension. After many thousands of miles underneath my Dad's fully battened cruising laminate main that in practice I never bothered adjusting batten tension, just left it at a sort of medium tension. The main "tweaking" I did was to play with twist a lot more than we do racing. And in general to use more twist than I started out with. I suspect that this also had a lot to do with the shallow keel that was fitted to the boat, but might be worth bearing in mind.
I saw very little change in performance profile over the 10 years I sailed that boat. Though it's fair to say that when sold that main didn't have an awful lot left in it.
