Minerva
I got a too good to refuse, new old stock, raydome to add to my 34ft centre cockpit boat in the Black Friday sales.
Now I’ll need to fit it. It’s going on the back of the boat, not the mast - I have mast steps and if it’s on the front of the mast I won’t be able to climb the steps on the front of the mast past it…
I was going to put a pole up with a couple
of struts - fairly straightforward and simple. However last night saw 316 40mm handrail tube for an attractive price and they also got 90° elbows so don’t need to worry about bending the tube.
316 Radiused 90 Degree Elbow To Suit 42.4mm x 2mm Tube
3 Metre 316 Grade Stainless Steel Tube 42.4mm x 2.0mm Wall Thickness
I recon that a couple of goal posts could made, and either welded (got a mig machine in garage) or drilled & tapped easily to make a stern gantry to mount the radar on - plus could move the solar from the guardrails too and when we remake the tent, extend it to the arch providing a covered place to hang wet foulies to dry aft of the cockpit.
Think that’s what’s called scope creep…
What else should I consider / what am I overlooking?
Thanks.
Thanks.
