lamdar
New Member
I’m planning to add a lithium battery (LiFePo4) to my setup. I currently have a single lead acid battery charged by a questionable dynastart and 50W solar panel through a PWM. I’m thinking about either adding an 280ah lithium to feed all the auxiliary devices, or simply replacing the lead acid battery with the lithium (the maximum power draw is 200A for a few seconds for the dynastart) to use for everything. I’ve read that lithium batteries can’t be used for engine start. However I don’t understand why given that the current draw is within the limit of the battery. It would be much simpler to replace the lead battery with a large enough lithium. And if I add lithium side by side with the lead acid, what’s the best way to set this up? Can I feed two batteries with a single solar panel and two regulators? ( one PWM and one mppt)
