Scubadoo
If you want super cheap solution just for tea at anchor for now, just take a flask, fill up from the kettle before you leave your berth or home.
whisperpower guy is in shamrock quay. Parts easy to get and sensible price (exhaust temp switch)Generator manufacturers I've found, in alphabetical order. Any obvious winners there in terms of reliability and 'value'? Or to be avoided for that matter... !
Beta Marine
Cummins Onan
Fischer Panda
Kohler Power
MASE (mcanderson)
Paguro
Westerbeke
WhisperPower (Elessar)
Ideally would need to be supported by a local service agent. Hamble area.
OK that makes sense. Some are 5Kw / 4KVA.whisperpower guy is in shamrock quay. Parts easy to get and sensible price (exhaust temp switch)
Remember you only need about 3kW with no aircon. Shorepower is 3.5kW or thereabouts definitely no more than that...
Not sure I can do bothIt is good to have an inverter too for use underway so it's easy to start with that and fit the gennie one you've actually done some boating!
Got to come out to fit a gennie of course.
Bilge pump testing, that made me smileWhere's your sense of adventure? If you're real quick with the insertion of seacocks no need to come out
Have a good look about. My boat had a genny but the P.O. gave up on it in disgust and fitted an enormous hot water calorifier in it's place good for a family of 4 for two days without running the engines. All the fittings are there but blanked off including an underwater exhaust. I would not be surprised if a genny was a OEM fixed feature of any cruiser rather than an optional add on. BTW yes I have tested if my bilge pumps could handle any of the seacocks bursting. A live test as it were. We're good![]()
Luckily we are faster than brucek , so social distancing is easy .Get you with your attention to detail lol, The lack of fun-box raiding is making you sensible!??????
just seen Keto at swanwick supply Whisperpower.OK that makes sense. Some are 5Kw / 4KVA.
Not sure I can do both... and that had occurred to me, needs cooling and exhaust skin fittings. So next Spring.
If it's only for a cup of tea or simple cooking what about this for a temporary measure.
Halfords Portable Gas Stove 2019 | Halfords UK
[QUOTE="BruceK, post:
Sacrilege! How very uncivilised to even suggest that![]()
