Plum
All sounds very complicated
I will add it inline....the only possibility is that the flow isn't high enough and the heater trips....in which case I will reduce the output of the heater.....till it does work.
I did a similar thing on my water heater when run on generator...and most people here said "NO! It won't work!" And it turned out to work perfectly....��
I shall report back....seems simple enough to me...the d4 is what 4kw? So I'm proposing running it with 0.9kw on the same fan but that won't have enough flow? Mmmm....let's find out.
I was just asking if anyone has tried it...seems like I will be the trailblazer....��
Certainly an interesting experiment. Looking forward to learning from you.
Www.solocoastalsailing.co.uk
