Looking again at your sketch, you need to fit the tee on your backbone not the spur that goes to you plotter, you don’t appear to have a backbone cable just the mutli block, your will need to remove one of the blue end plugs, get a short black/ blue backbone cable, this goes into the tee on the blue side and the end stop goes into the other side blue of the tee, you then connect your new device onto the tee at the white socket.
it’s easy when you’ve got your head around it and then really easy to add stuff later.
If the OP wants to retain the ST60 stuff he needs to keep this in the system, thus is needed for STng to Seatalk bus conversion. This is how I started and eventually removed this as all was moved to N2k instruments. Now have both device net and STng on backbone with spare connections for both.if you want to use raymarine kit and cables then yes.
if the device being added is n2k…..why involve the block at all?
You missed my point…..STNG is n2k with different plugsIf the OP wants to retain the ST60 stuff he needs to keep this in the system, thus is needed for STng to Seatalk bus conversion. This is how I started and eventually removed this as all was moved to N2k instruments. Now have both device net and STng on backbone with spare connections for both.
YesSo will my AO6045 lead fit into the Garmin tee?
Yes as it’s the adapter cable, but the Garmin tee will not fit your backboneSo will my AO6045 lead fit into the Garmin tee?
No it has one….but it’s n2k…..then you use a lead to convert it to the stng connectors with lead a06045.Ow I’m a bit confused, does the aximon have 2 STng ports? One is already connected to the adapter. Does he not have to connect to the backbone? Which is currently in the form of the adapter only? The Garmin steadycast has a built in drop cable but still has to go to a backbone connection?
im fully aware of the connection types as I have both in my system
I have never put a tee in a spur drop to feed two instruments, if it works as you say fine but all the stuff I’ve done and read details to use the backbone
