RD60
Active Member
I have an Axiom XL and would like to add a camera. .
What are the best, low cost, options to achieve this?
Thanks for this. Considering aft facing external camera and maybe one in engine spaceWhat will the camera be used for?
Where will it be located?
In my experience, you have to be a bit careful with IP cameras.
They "stream" so there can be a delay which is a bit off putting but, more importantly, a delay within a docking camera might not be desirable.
My docking cameras are cheap analogue RGB which have been working fine.
They feed into the RGB inputs on my Raymarine G Series displays.
My system is now 13 years old - there may be better (faster) IP cameras out there now but I would check before fitting.
Especially if fitting cheap, non marine, IP cameras.
Yep - I it should be better these days but the OP was asking about low cost cameras.Most IP cameras nowadays have very little latency (less than 500ms). You should easily be able to get sub second latency onto an Axiom screen.
We can easily get sub 1s latency including sending it half way around the world
I think the Axiom's will work with pretty much any ONVIF compliant camera. Axis are a decent make.
Because the rear view from our wheelhouse is none existent I wanted a continual view behind but didn’t want to use the Axiom display, preferring to keep that for radar and navigation. We had space for a separate monitor so I bought a kit from this outfit for not a lot of gold in boating terms and it does the job. The one we bought will take feeds from three cameras but we on,y have one, primarily because the conduit taking wires down the windscreen mullion is full!
Thats a useful linkBecause the rear view from our wheelhouse is none existent I wanted a continual view behind but didn’t want to use the Axiom display, preferring to keep that for radar and navigation. We had space for a separate monitor so I bought a kit from this outfit for not a lot of gold in boating terms and it does the job. The one we bought will take feeds from three cameras but we on,y have one, primarily because the conduit taking wires down the windscreen mullion is full!
In my experience I have used several of those type of cameras for many years and found they tend to fail after about 1 to 2 years in a marine environment, however they are cheap and can be regarded as throw away cameras.I just unpacked my reversing camera from Ebay and this is what I got in the box. I will list the items as it is not obvious what they are from the pic
1) 7 Inch Screen
2) Camera with hood, mount and Infrared
3) Screen mount for flush installation
4) Window Sucker Mount
5) Flat surface mount with sticker and screw holes
6) Coil of wire - single from camera to monitor
7) 12V Plug and power wire with red push button switch but no USB Passthrough
8) Separate Power wire if you want to hard wire
9) Bag of 4 small screws
10) Remote control
11) Monitor instructions but no other instructions
12) The screen has an input for a second camera but this kit only came with 1 camera
Not sure what the green wire is in the pic I think this is for the reversing line grid thing
All in all looks a reasonable package for £57 delivered
Problem with the reversing camera kits is that the screens are rubbish, only good for use in the dark, or lots of shade
Another thing to consider with Docking Cameras.
Do you want the image mirrored or normal?
All this is far too complicated for my little brain to take in at the precise moment that I need the information.
