Yeoman_24
I currently have a 2 x 100 amp leisure batteries on my Moody 30 with 28hp Beta Marine engine and 65 amp alternator.
1 leisure battery is used for starting, 1 for ‘house’ and a 1 / both / 2 switch for starting, alternator charging, battery use, etc....... and that’s my set-up.
I’m thinking of adding a standard 65amp (roughly) starter battery and then have the 2 leisure batteries as house batteries.
Would forumites recommend this or, would I be better served by a 100 amp alternator instead?
The main reason I ask is I suffer from sleep aponea and have to use a travel CPAP machine which is a bit, ‘amp’ hungry. Manufacturers are gits to try and get me buy a 15v travel battery for .... £300 !!! I have their inverter which runs the machine from 12v through 15v inverter.
Hope this all makes sense but I can provide any links to CPAP data if required to help solve the problem!
